I have a 1995 Ford Taurus. The ignition switch stays in the run position. It will start and run, but not shut off. I changed the ignition key lock cylinder but that did not fix the problem. Researched the problem online and looks like it is the plastic linkage between the key lock cylinder and the ignition switch, or the ignition switch itself. I have not been able to find out how to do this repair or diagrams of the steering column that shows these parts. Any instructions or online links are appreciated.
Thanks Mike
Thanks Mike
Apr 5, 2009 at 2:48 AM
