just replaced the brake lines going to the rear axle (the old ones were rusted) and the Brake Load Sensor Proportioning Valve (ford part # e6dz-2b547-a) on a 95 Taurus sedan with ABS and 4 wheel disc brakes. I placed a load on the rear axle (so the proportion valve would allow brake fluid to reach the calipers) and can't get any brake fluid to bleed from the calipers. What else should I do?[img:c43758916e]http://www.2carpros.com/forum/automotive_pictures/328422_Brake_Load_Sensor_Proportioning_Valve1_1.jpg[/img:c43758916e]
[img:c43758916e]http://www.2carpros.com/forum/automotive_pictures/328422_Brake_Load_Sensor_Proportioning_Valve2_1.jpg[/img:c43758916e]
Mar 7, 2009 at 12:14 PM
