HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Taurus
Engine
Cylinder Head
Gasket
Blown
1995 Ford Taurus head gasket
SKRUSENSTERNA
MEMBER
1995 FORD TAURUS
4 CYL
2WD
AUTOMATIC
38,000 MILES
Symtoms of blown head gasket.
Sunday, August 1st, 2010 AT 9:42 PM
MECHANIC
Fill the radiator up leave the cap off and start the car-if it's shooting out coolant or bubbling-more likely you have a blown head gasket and also engine oil will look like milk shake. Could be also a crack head or block.
SPONSORED LINKS
Sunday, August 1st, 2010 AT 9:51 PM
Please
login
or
register
to post a reply.
Related Cylinder Head Gasket Blown Content
2001 Ford Taurus Blow Head Gasket
I Have A Blown Head Gasket And I Tried The Blue Devil Two Day Ago It Less Water On One Of The Spark Plug And I Wanted To If It Ok To Try...
Asked by
Sky13
2001
FORD TAURUS
GUIDE
Cylinder Head Gasket Blown Test
Diagnosing a blown head gasket in an automotive engine requires a systematic approach to ensure accurate results. This guide will walk you through the necessary steps to...
1996 Ford Taurus Possible Blown Head Gasket
My Check Engine Light Is On. A Mechanic Has Shown Me The Computer When He Hooks It Up And It Has Shown, A Miss In One Of The Cylinders And...
Asked by
ontivmi1
1 ANSWER
1996
FORD TAURUS
2003 Ford Taurus Blown Head Gasket
Engine Mechanical Problem 2003 Ford Taurus 6 Cyl Front Wheel Drive Automatic 90k Miles The Car Apparently Got Hot An Seized Up. After...
Asked by
mestill
1 ANSWER
2 IMAGES
2003
FORD TAURUS
2000 Ford Taurus Blown Head Gaskets And Coolant In Oil
2000 Ford Taurus 4d Wagon Mileage: 75,000. Do Blown Head Gaskets, Cause Some Coolant To Leak Into The Oil, Always Result In The Need To...
Asked by
2CP-Archives
1 ANSWER
2000
FORD TAURUS
Blown Head Gasket?
We Have Replaced The Over Flow Tank, Not Sure If This Is What It Is Called, But This Is The Third One. It Keeps Coming Out Under The Cap...
Asked by
deutsch1957
2000
FORD TAURUS
VIEW MORE
SPONSORED LINKS
Coolant Mixing with Oil
Surging
Engine Oil Change and Filter Replacement
Online car repair manuals
