1995 Ford Taurus Grounding cables
200,000 MILES • 6 CYL • FWD • AUTOMATIC
BRENDDEN
The large gauge grounding wire came disconnected from the end opposite the battery, and I can't find where it connects, or a site that has an answer.
Dec 16, 2009 at 1:35 PM
BMRFIXIT
  • 19,053 POSTS
Black negative battery cable connect to the starter stud on tranny bell housing
Dec 17, 2009 at 1:43 PM
BRENDDEN
I can't figure out what you mean, is there any way you can get a picture or more details?
Dec 19, 2009 at 1:07 AM
BMRFIXIT
  • 19,053 POSTS
Do you know where your starter is ?
one of its bolts is a stud
its a bolt and have a nut on it
negative ground wire connected to it
so that black wire run from the battery negative side to the starter stud
sorry have no picture for you but I will look and will post if became available
Dec 19, 2009 at 11:12 AM
