1995 Ford Taurus GL V6 3.8l. 166,500 miles.
FRANK50
  • 1995 FORD TAURUS
Car is over heating. To around the 3/4 level. Usually it only goes to 1/4 or 1/2. No smoke or leaks. 3 years ago replaced the radiator, hoses, water pump, radiator cap. Havent had the system flushed. Driven only 15k miles since then. I noticed some black sludge in the radiator when I took up the cap off. Also there was a recall on the cooling fan circuit breaker that I didnt have done about 5 years ago. Also this car had a bad heater core that was not replaced. The mechanic at that time did some kind of rerouting to bypass the heater core. My question is could the heater core rerouting have anything to do with this? Or is it more likely a head gasket, or a bad thermostat ( I dont know if it was ever replaced), or the cooling fan. Any help would be greatly appreciated. Thank you.
Monday, October 29th, 2007 AT 4:49 PM
SERVICE WRITER
  • 9,123 POSTS
In a nutshell you have avoiding doing things that should have been done.?
The heater core rerouting has nothing to do with this.
Does the cooling fan come on?
Monday, October 29th, 2007 AT 6:11 PM
03TAURUSSUKS
Had this very same problem with our "95 Taurus but, at 64,000 miles.
We found out it was the head gasket needed replacing and mechanic recommended scrapping the car.
It would need a complete rebuild.
Saturday, December 15th, 2007 AT 3:12 PM
