1995 Ford Taurus gear level position
109,000 MILES • 6 CYL • 2WD • AUTOMATIC
JJNOGA
My 95 taurus seems to be having a problem not knowing that it is park or neutral for starting. It seems to be getting worse and worse. I can't start it until I fiddle with the level position of the stick and play with it. Then all of a sudden it knows it is either in neutral or park and starts. Does anyone know if this is an easy fix??? Thanks, Janice
Jan 20, 2009 at 4:23 PM
BMRFIXIT
  • 19,053 POSTS
i would suspect neutral safety switch on tranny
check its connector too
check starter small wire (S)
Jan 20, 2009 at 10:15 PM
