1995 Ford Taurus fuelpump
1995 FORD TAURUS
17,000 MILES • 4 CYL • 2WD • AUTOMATIC
THANCOCK
i ant getting any fuel and i was whanting to know where the fuel pump relay is located because i put a new starter on and it wont get any fuel now and the feul pump shut off switch is on but maybe bad how can i tell? i need help fast.
Oct 28, 2008 at 7:52 AM
BMRFIXIT
  • 19,053 POSTS
1st key on,fuel pump should come on for a few seconds and also when cranking
check for power at the fuel pump connector by the gas tank
if you have battery power while cranking
replace fuel pump
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Oct 29, 2008 at 1:17 PM
