1995 Ford Taurus Fuel pump running when car is off
MBEKEBREDE
  • 1995 FORD TAURUS
  • 6 CYL
  • FWD
  • 145,000 MILES
My cart was turning the fuel pump on when the car was not. I took it in and they replace the portion of the computer that controls the temprature controls. This helped for about tow weeks and then the pump kept coming on agian after the car was off. THis burned out the pump and now that needs replaced. What could be the problem that is turning the fuel pump on?
Wednesday, May 5th, 2010 AT 1:12 PM
MERLIN2021
  • 17,250 POSTS
Tuarus has a part called the CCRM(constant control relay module) it has the relays for cooling fans and fuel pump in it, this is the likley problem, replace the ccrm, or the fuel pump relay if you want to try cheap first...
CCRM is on the upper radiator support.
https://www.2carpros.com/forum/automotive_pictures/62217_CCRM_PCM_2.jpg
https://www.2carpros.com/forum/automotive_pictures/62217_CCRM_Circuit_1.jpg
Wednesday, May 5th, 2010 AT 1:29 PM
