1995 Ford Taurus fEUL PROBLEM
125,000 MILES • 6 CYL • 2WD • AUTOMATIC
FREEMAN11
I have a 1995 Ford Taurus and it will run good for a bit and than stall out. I need to know what your thoughts are and if you can tell me or send a picture showing where the fuel filter and fuel pump are located?
Apr 2, 2010 at 9:59 AM
  • 75,988 POSTS
Could be an Ignition or Fuel system problem might not be the fuel filter and fuel pump -Do below we start here
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Apr 2, 2010 at 10:13 AM
