1995 Ford Taurus external oil pump
156,000 MILES • 6 CYL • 2WD • AUTOMATIC
RSELLERS
  • 6 POSTS
there is a oil leak coming from the oil pump,I need to remove it and replace the gasket.How difficult is this to remove and replace back?
Mar 1, 2010 at 1:29 AM
BMRFIXIT
  • 19,053 POSTS
what do you have for engine ?
did you check the pressure switch and oil pan gasket for leaks
Mar 1, 2010 at 10:03 AM
RSELLERS
  • 6 POSTS
oil pressure switch is fine. its a 3.8 v6 with an external oil pump. thats where th leak is comin from
Mar 1, 2010 at 11:44 AM
BMRFIXIT
  • 19,053 POSTS
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic1_667.jpg
Its not a bad job Do not use silicone and no special tool needed
Mar 1, 2010 at 12:08 PM
RSELLERS
  • 6 POSTS
thanks for th diagram! how many bolts are there to remove? 4??
Mar 1, 2010 at 11:35 PM
BMRFIXIT
  • 19,053 POSTS
remove oil filter and 4 bolts
Mar 2, 2010 at 11:05 AM
