1995 Ford Taurus Engine will not turn over
RONSR1948
Electrical problem
1995 Ford Taurus 6 cyl Front Wheel Drive Automatic
Prior to putting a new battery and starter on this vehicle car would not turn over. The cable from the battery to starter gets hot but starter will not turn engine over but it did turn over once without key start when cable was crossed when hooked up though it engages but does not turn engine over
Dec 16, 2009 at 7:40 AM
BMRFIXIT
  • 19,053 POSTS
What ?? can you elaborate on what is happening or what is it you trying to do
if cables were crossed have to check fuses wiring and links
Dec 16, 2009 at 9:24 AM
