1995 Ford Taurus engine will not run
1995FORDTR
Engine Performance problem
1995 Ford Taurus 6 cyl Front Wheel Drive Automatic
I've change the pcm, ecc and the fuel pump. the car will not light off. I.ve got 30 psi fuel, it seams that the ejector's are not working. any help would be nice.
Jul 25, 2009 at 1:48 PM
BMRFIXIT
  • 19,053 POSTS
Key on do you have check engine light on
you should if not check relays
do you have spark
do you have power at the injectors with key on
Jul 27, 2009 at 3:11 PM
TOMMY32
IS THIS A SHO MODEL TAURUS?
Jul 29, 2009 at 1:04 AM
1995FORDTR
no, just plan gas unit, through mor testing found the ing mod bad
Jul 29, 2009 at 12:18 PM
