[quote:d2a35e4a4d="Ford4Taurus"]Engine Cooling problem
1995 Ford Taurus 6 cyl Front Wheel Drive Automatic 200,00 miles
Can I use a coolant stop leak product?[/quote:d2a35e4a4d]
It would depend on how servere the leak is. If it is just a small pin hole or a gasket leaking then you can try some Radiator Stop Leak. If it is a major leak or leaking from the Water Pump you should have it fixed.
Feb 12, 2009 at 5:58 AM
