1995 Ford Taurus check engine light
154,000 MILES • 6 CYL • FWD • AUTOMATIC
JYLOTTIE
my cars check engine light wont go off after it was repaired, i had the guy at autozone go to reset it but he could not find the plug for the computer and told me only 96 and above has them how do i get my check engine light to go off?
Oct 1, 2008 at 9:56 AM
BMRFIXIT
  • 19,053 POSTS
Need to get the codes and fix it
you can remove the battery negative side for a min or so that will clear the code and check engine but will not fix the problem check engine light will come back on as so as PCM check and find the trouble
need to get the codes
need manual CHECK IT @
http://www.2carpros.com/kpages/auto_repair_manuals.htm
Oct 2, 2008 at 10:44 PM
