1995 Ford Taurus car shakes
FHNTRUMPET07
Shakes or Wobbles problem
1995 Ford Taurus Front Wheel Drive Automatic
ford tauraus shakes when going over 40 miles per hour. Seems to orginate from the front right side of the car. What could this be?
Nov 18, 2009 at 12:35 PM
OBXAUTOMEDIC
  • 3,720 POSTS
Could be a few things....
Ball joint...
Tie rod...
Wheel Bearing...
Bent rim....
Tire trend seperating...
To check you will need to raise vehicle. Try moving tire by pushing in at top and pulling out at bottom if has a lot of play the could be wheel bearing. You can also look at the back side while trying to move the wheel and look at the small diameter rod that attaches to the rear side of the wheel if there is a lot of movement there then the tie rod end is bad.
Nov 18, 2009 at 12:49 PM
