1995 Ford Taurus Back brake lights
VERNONTX
1995 Ford Taurus
back brake light will not come on. fuse is good , turn sigals work and backup lights work . Did find a wire loose under the dash on the brake pedal how do u replace that wire
Nov 8, 2009 at 8:00 AM
  • 75,988 POSTS
Check and test the wiring to the brake switch and the switch itself
Nov 8, 2009 at 8:43 AM
