1995 Ford Taurus AC not working!
155,000 MILES • 6 CYL • 2WD • AUTOMATIC
CDPMRP726
Last summer, I noticed the AC was working, but not as cool as it normally ran. I also noticed it seems to kick on and off (you could feel it as you drove). The other day, I tried to run the AC, and to no suprise it did not work (no cool air). I am not even sure if it is working. Any uggestions would be great on what the problem is (low freon or something worse). Thanks!
Apr 28, 2008 at 8:56 AM
MASTERTECHTIM
  • 4,750 POSTS
for sure your out of freon. you must have it charged then leak tested to find the source of the leak.
Apr 28, 2008 at 9:43 AM
TAURUSWHEEL
  • 718 POSTS
Pull the connector off the receiver-dryer bottle, big round black bottle located under the eec4 and abs connector mounts. Jump the connectors see if the compressor locks up, only run for a couple of seconds. If so, you can buy r134a with a connector, gauge and instructions.
Apr 28, 2008 at 1:26 PM
