1995 Ford Taurus 95 Taurus ignition control module replacem
1995 FORD TAURUS
REDJET20
Engine Performance problem
1995 Ford Taurus 6 cyl Front Wheel Drive Automatic
How do you replace the ignitiion control module on a 1995 Ford Taurus, 3.0 V6 ?
Mar 19, 2009 at 8:06 AM
JGAROFALO
  • 489 POSTS
Unless you have the flexible fuel engine or the SHO, the ignition module is on the distributor. To replace it, you need to loosen the hold down bolt on the distributor. Then turn the distributor to access the bolts holding the module to the distributor. You will need a 5.5 mm thinwall socket to remove the bolts. Then pull the module downward to disengage it from the PIP sensor in the distributor. To install the replacement module, reverse the procedure with care to the following:
The replacement module must have dielectric compound applied to the surface that contacts the distributor. This is necessary for heat transfer to keep the module from overheating. Timing must be reset to specification.
Mar 19, 2009 at 1:03 PM
