I HAVE PUT A NEW FUEL PUMP NEW COMPUTER NEW DISTRUBITOR ON MY CAR AND NOT GETTING FIRE FROM COIL PAK TO THE DISTRIBUTOR WHAT IS WRONG WITH IT? I HAVE TRIED EVERYTHING I KNOW POSSIBLE.
Sunday, October 5th, 2008 AT 11:50 AM
2CARPRO JACK
MECHANIC
Grab a tets light. Do you have power at the coil with the key on? If so, does your distributor have the ignition module mounted on the side of it?
SPONSORED LINKS
Wednesday, October 8th, 2008 AT 7:31 AM
KRMT
MEMBER
I put new distributor cap and rotor and module that is on the side. Im not getting feed back. Everything has power but fuel pump isnt getting power but there is power from coil pak to distributer. Have tested it and I am getting power to the distributor. Fuel pump, whole coil pak, whole distrubitor are all new parts installed and im stuck as to why there is no power to it.
Wednesday, October 8th, 2008 AT 2:28 PM
2CARPRO JACK
MECHANIC
You said there is and isnt power to the fuel pump. Have you checked to see if there is power at the coil?
Wednesday, October 8th, 2008 AT 3:53 PM
KRMT
MEMBER
There is power to the coil pak BUT no fire from coil pak to distributor. Changed module distributor cap rotor and even put a new computer in it. Put test lights on injecors and no signal they didnt flash.
Wednesday, October 8th, 2008 AT 4:27 PM
2CARPRO JACK
MECHANIC
Need to get it on a scanner to see if the ECM has recorded any failures.
SPONSORED LINKS
Wednesday, October 8th, 2008 AT 4:57 PM
KRMT
MEMBER
Where can I get a scanner at or do I have to take it to a shop?
