1995 Ford Taurus
12,800 MILES • 6 CYL • FWD • AUTOMATIC
MOUSES MEATS
The problem I,m having is the car is cutting out on acc. and will blow the ign. coil fuse. Replaced the coil same problem. Any suggestions?
Oct 7, 2010 at 5:39 AM
  • 110,248 POSTS
Have you checked wiring for damage that could cause a short? Also, how long does it take for the fuse to blow?
One last question, by acc., do you mean accelleration or accessory position on the switch?
Oct 7, 2010 at 3:13 PM
MERLIN2021
  • 17,250 POSTS
Make sure the tack wire isnt grounded out someplace, could be in a wiring harness that moves with the movement of your engine during acceleration.
Oct 7, 2010 at 3:15 PM
