How to fix/replace brake booster on 1995 Ford Taurus
Apr 7, 2010 at 3:14 AM
✓Experienced Mechanic
They are not repairable. To remove it is a pain because of how it's mounted. You will need to remove the master cylender, disconnect the brake pedal to it, and then from under the dash, there are 4 bolts that hold it in place. (not easy to get to).
