1995 Ford Taurus
60,000 MILES • 6 CYL • FWD • AUTOMATIC
FT95
  • 9 POSTS
There is a foamy mixture in my coolant overflow container.I checked the oil cap and it's clean.I haven't driven the car for several months but I do start it up and idle.It is a 3.8 liter.Head gasket was changed by Ford years ago.I had no issues with it when I did drive.Could it be tranny fluid?
Jul 27, 2010 at 1:57 PM
  • 110,248 POSTS
It could be ATF if there is a problem in the radiator or oil from the engine if there is a bad head gasket. Is the engine running good? Have you checked the transmission fluid to see if it is still full and clean?
Jul 27, 2010 at 3:55 PM
FT95
  • 9 POSTS
The engine runs good.I've owned the car since 1999 and never changed the radiator.The tranny fluid is full and clean.I haven't started the car since I saw the overflow dirty.
Jul 28, 2010 at 7:19 AM
  • 110,248 POSTS
Are you sure the system doesn't just need serviced?
Jul 28, 2010 at 4:39 PM
