1995 Ford Taurus
RHOWARDLSU
  • 1995 FORD TAURUS
1995 Ford Taurus LX 86000 miles 3.8 L Engine:
Lately I have been having two problems which I think are related. Whenever I am driving for more then 5-10 minutes, the will stall. Most of the time idling, but today it happens while I was driving around 35 MPH.
I also have notice that once in awhile when my car is sitting for 4-5 hours it has a hard time starting. I know when it won't start because of a buzzing noise coming from the relay over the fan. I also notice my RPM gauge is spiking around 7500 RPM when it is in the on position.
I also notice if I sit in park for a little while, I notice the RPM gauge fluctuate between 600-1000 RPM. To me this seems like something electrical wrong with my fuel system.
I look forward to your advise, thank you.
Thursday, May 10th, 2007 AT 10:07 AM
2CARPRO JACK
  • 11,533 POSTS
Is the check engine light on? When it dies is it losing spark or fuel? Have the PCM scanned for codes
Thursday, May 10th, 2007 AT 11:23 AM
RHOWARDLSU
  • 8 POSTS
The check engine light is not on normally. It only comes on when the car stalls. Would it still give out a PCM code even if the light is not on?
Thursday, May 10th, 2007 AT 12:07 PM
RHOWARDLSU
  • 8 POSTS
I am not sure if it is losing spark or fuel. There isn't a leak, and if the relay isn't buzzing it catches instantly. If it is buzzing, it has a hard time catching.
Thursday, May 10th, 2007 AT 12:40 PM
