Check on the brake pedal arm for the BOO(brake on off) Switch, may be out of adjustment, or no good, test with OHM meter, first thest across the switch, should read infinity, then press the button, and it should drop to zero.
SPONSORED LINKS
Friday, July 4th, 2008 AT 6:10 PM
