1994 Taurus 3.8 will not start relay control module clicks
LARRYHE
  • 8 POSTS
As soon as you turn the key on, the relay control module starts clicking. I can see and hear the service engine light and the fuel pump in sync with the clicking. The motor will turn over but does not start.
May 22, 2006 at 7:14 AM
LARRYHE
  • 8 POSTS
I found the problem. Pin 15 was not grounded. It supplied the ground for all the relays and transistors. It was a black/green wire that ran to a connector just below the CCRM mount. The connector had been hot and the pins were not making cotact. The other side of the connector screw to the core support just the side of the CCRM. Hope this helps someone.
Mar 16, 2017 at 5:06 AM
