1994 Ford Taurus WILL NOT RESTART
10,000 MILES • 6 CYL • 2WD • AUTOMATIC
MARISCALFAM
WHY IS IT THAT AFTER DRIVING I TURN OF CAR SOMETIME CAR WILL NOT RESTART TILL IT COOLS DOWN IT WILL CRANK LIKE ITS GOING TO START BUT WILL NOT TILL IT COOLS
Dec 24, 2009 at 1:12 PM
  • 75,988 POSTS
No start condition:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard.
Dec 25, 2009 at 10:57 AM
