1994 Ford Taurus wheel bearing
PH26604
Suspension problem
1994 Ford Taurus 6 cyl Automatic 129,00 miles
i have replaced my front left wheel bearing 2 times in the last 2 weeks, its like after 3 days it goes out and i can now move my tire again, why or what could be doing this?
Apr 30, 2008 at 2:58 PM
BLACKOP555
  • 10,386 POSTS
it is being installed improperly, have it professionally done.
make sure the grease/oil seals and bearing races are being replaced and installed squarely not uneavenly.
Nov 10, 2017 at 4:27 AM
TAURUSWHEEL
  • 718 POSTS
the steering knuckle could be internally damaged, which would require replacement, it happened to me.. bought a used one from a wrecking yard, have someone check it out.. are the bearings destroying themselves or is the nut coming loose??? the nut is a one-use deal, it stretches from torque applied, recommended only one use
