1994 Ford Taurus Starting problems
156,000 MILES • 6 CYL • FWD • AUTOMATIC
KCROUCH17
Sometimes my car will run great for a couple of weeks, then it will crank over very strong but won't start. I have had it at my mechanic, but unless he can duplicate the problem, he can't find anything wrong. The A/C is not working, the back doors and windows can't be opened from inside the car. I can't afford to take it to Ford, but they charge way to much. Please help.
May 16, 2008 at 6:04 AM
BLACKOP555
  • 10,386 POSTS
im in the same position as your mechanic, sorry.
i cant help you diagnoss this unless you can find out if its not getting fuel to the engine or spark/ignition when the vehicle wont start.
Mar 16, 2017 at 5:43 AM
KCROUCH17
I am getting fuel, an I am getting a spark. I was told it might be the CCRM or PCM?
BLACKOP555
  • 10,386 POSTS
so everything is just the same when the vehicle wont start as when it will?
engine cranks the same
same fuel pressure, same fuel injector pulse.
same spark color, def, speed?
