1994 Ford Taurus Starter relay wont engage unless engine is
216,000 MILES • 6 CYL • FWD • AUTOMATIC
GEORGE BRANDT
My problem on my 94 taurus GL 3.0 liter is that intermitently when i turn the key to start it i will not hear the fuel pump engage and i will hear only a small click from the starter solenoid. I then hop out of my vehicle, pop the hood and manually turn the engine over by pulling on the serpentine belt. This occurrence happens about 1 in 20 times. The fuel pump will then presuure up .Then the car will start and run perfectly. What causes this problem ? I have clean and new electrical leads with good contacts. Baffled in Alberta Canada .....
George
Jan 1, 2009 at 8:27 AM
BMRFIXIT
  • 19,053 POSTS
Check around the starter area and its mounting bolts for a loose ground cable
remove nut
remove cable clean stud and tighten and reinstall cable and nut
check ground wire to the relay box by the radiator
good luck
Jan 1, 2009 at 10:42 PM
