Transmission problem
1994 Ford Taurus 6 cyl Two Wheel Drive Automatic 48xxx miles
I have a 1994 ford taurus and my speedometer does not work. i brought the car aware of the problem. it also has a slight slip in the tranny as though it seems when shifting into second gear, as if taking off at a green light but after that it drives good. i took it on the highway and the needle began to jump around but it wasn't really steady..at low speeds it does nothing. My check engine light is not on!
Mar 23, 2010 at 5:14 PM
