A friend gave me this car for free because the dealer told him it would cost over $2000 to replace the trans. Could you tell me what would cause the trans to slip when starting from a stop? It only slips after it gets worm. It does not matter if it is in rev or any other dive gear. Once you are moving it does not slip at all. The fluid level is slightly above full, it does not smell burnt, does not look to old and viscosity feels about normal. An other friend suggested that the filter may be clogged. I am going to put in a new one tomorrow. If that does not change any thing I was thinking the problem may be the torque converter. Your thoughts would be greatly appreciated.
Thank you
Thank you
Mar 20, 2009 at 1:17 PM
