car spits and sputters. Running rich. I've repalced the MAF sensor since there is not BAP or MAP sensor. Any ideas on what this could be?
Sep 16, 2008 at 9:05 AM
OBXAUTOMEDIC
✓Experienced Mechanic
[quote:53897fa105="tomsmith2448"]Engine Performance problem
1994 Ford Taurus 6 cyl Front Wheel Drive Automatic 164000 miles
car spits and sputters. Running rich. I've repalced the MAF sensor since there is not BAP or MAP sensor. Any ideas on what this could be?[/quote:53897fa105]
Is your Check Engine Light On?
When was your last tune up...... Spark Plugs and Wires
Sep 16, 2008 at 10:43 AM
TOMSMITH2448
MEMBER
Yes, the car was just tuned up. New plugs and wires.
Sep 16, 2008 at 10:52 AM
OBXAUTOMEDIC
Is that also a yes about the engine light. do you think you can get it to your local auto zone so they can pull the codes. if so post codes here.
