1994 Ford Taurus no power to injectors on 94 taurus gl 3.8l
1994 FORD TAURUS
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
JAMESRHOLLIN
have a 94 taurus gl 3.8l that will not start. i have spark, and the right fuel pressure on the fuel rail. i have no voltage to the injectors. i have replaced the distributor and the relay module but still no luck. any ideas where else the problem could be?
Jun 26, 2010 at 6:29 PM
Check and test the PCM power relay at the CCRM on center of upper radiator support
Jun 26, 2010 at 6:43 PM
