1994 Ford Taurus NO HEAT
WISCONSIN
  • 1994 FORD TAURUS
  • 6 CYL
  • 180,000 MILES
I HAVE NO OR VERY LITTLE HEAT I REPLACED THE HEATER CORE THERMOSTAT FLUSHED THE SYSTEM THE A/C WORKES FINE BUT THE HEAT WILL NOT WORK IF MY CAR SITS IN A GARAGE THE HEAT WORKS FINE BUT WHEN I STARK TO DRIVE IT STARTS TO COOL PLEASE HELP SORRY I HAVE SPENT ALL OF MY MONEY ON REPAIRS BUT I WILL DONATE AT A LATER TIME
Wednesday, January 30th, 2008 AT 8:18 PM
BMRFIXIT
  • 19,053 POSTS
Heater hoses both hot
if so check the blend door
check water pump
Wednesday, January 30th, 2008 AT 9:39 PM
EZMONEY
  • 10 POSTS
If you have changed the anti-freeze you might have a air lock (BUBBLE) IN THE SYSTEM. YOU HAVE TO PURGE THE AIR FROM THE CLOSED COOLING SYSTEM.
Wednesday, January 30th, 2008 AT 10:51 PM
