1994 Ford Taurus help
125,000 MILES • 6 CYL • FWD • AUTOMATIC
STONEFARMER
I have this taurus that i picked up for my son to drive
well that was three years ago
bad trany so they said it was flashed no good
now it was rebuilt installed same thing when the car warns up and you stop it will not go forwored or back
when it cools down it works
check the pump presser is good and no codes
its the same as be for
is it a val that got missed on rebuilt
some times if you rase the rpms it will just drop in
please help we now have two kids driveing and my wife is i told you so
Sep 21, 2009 at 3:29 PM
KHLOW2008
  • 41,812 POSTS
Hi stonefarmer,
Thank you for the donation.
Yes, this seems a fault with the valve body or controls.
In order to understand the problem better, I need to know the model of the tran in your vehicle.
Since problem is present after rebuilt, you should refer back to the shop which did the repair.
Sep 22, 2009 at 1:22 AM
