1994 Ford Taurus fuel pump regulator
STEPHEN M ASHLEY
Engine Mechanical problem
1994 Ford Taurus 6 cyl Front Wheel Drive Automatic
I need to know where the fuel pump regulator is located on this car ?
Jan 29, 2010 at 5:50 AM
  • 75,988 POSTS
The fuel pressure regulator is attached to the fuel rail
Jan 29, 2010 at 6:26 AM
MERLIN2021
  • 17,250 POSTS
The fuel pressure regulator is on the fuel rail, and has a vacuum line on it.
Jan 29, 2010 at 6:28 AM
  • 75,988 POSTS
You check the fuel pressure with and w/o vacuum-w/o vacuum it should increase 8-10psi-Good Morning Merlin
Jan 29, 2010 at 6:37 AM
MERLIN2021
  • 17,250 POSTS
Good evening Mr. Raz, do you look like that picture?
Jan 29, 2010 at 10:13 AM
