1994 Ford Taurus fuel pump problem
207,000 MILES • 6 CYL • AWD • AUTOMATIC
BABY_H5
I have been having some problems with my car shutting off while driving. Every time the engine shuts off, I can usually start it back up once it rests for about 10 mins or so, and I can usually drive it another mile or so. So far, everyone I've told my problem to has said that it is most likely due to a broken or malfunctioned fuel pump. I just wanted to get some opinions on what the problem may be. Thank you!
Aug 23, 2009 at 7:19 PM
  • 75,988 POSTS
You need to check the fuel pressure with a fuel pressure gauge designed for your fuel system to rule it out-might not be it if its producing the correct fuel pressure.
Aug 23, 2009 at 7:47 PM
