1994 Ford Taurus fuel pump
JREADY10
  • 5 POSTS
Engine Mechanical problem
1994 Ford Taurus 6 cyl Front Wheel Drive Automatic
hello
My taurus sho cranks up good when it cold then at s running temp i shut s down and wont crank until u wait awhile i change the coil box didnt help.when it hot it just turns over, and i can hear the fuel pump coming on strong every time. i need to know if thats still the fuel pump. and do i have to drop the tank to get to it
Mar 14, 2009 at 7:17 AM
JDL
  • 16,098 POSTS
Hello, when the vehicle refuses to start, do some of the basic tests. Have a helper crank it, check for spark and injector pulse. Check fuel pressure, any codes?
The pump is in the tank, you need to drop the tank so says the database.
Mar 14, 2009 at 7:32 AM
