1994 Ford Taurus Engine turns over, but will not start
123,000 MILES • 6 CYL • FWD • AUTOMATIC
LAURI_L
My drive belt broke while driving on the Interstate. When car engine died, I let the car coast to a stop. As we coasted, steam came from under the hood (water pump was disabled by loss of belt).
Towed car home the next day; checked the oil for water and the antifreeze {in the radiator overflow} for oil. Both appeared to be fine.
Replaced the drive belt, filled radiator. Hooked battery up to another vehicle with jumper cables to charge battery. Car turns over (sounds kind of whiny), but will not start.
Apr 16, 2009 at 6:42 AM
BMRFIXIT
  • 19,053 POSTS
check fuses
check for spark
check for fuel
do a compression test
Apr 16, 2009 at 1:49 PM
