1994 Ford Taurus Engine oil out of the hole measuring engin
SAYF
Engine Performance problem
1994 Ford Taurus 6 cyl Front Wheel Drive Automatic
Engine oil out of the hole measuring engine oil & no smoke
Oct 15, 2010 at 10:45 PM
MMPRINCE4000
  • 8,548 POSTS
Unless the oil pan is overfilled, it could be excessive oil pressure.
Measure OP with mechanical gauge.
Oct 16, 2010 at 12:39 AM
SAYF
[quote:22004eadf8="mmprince4000"]Unless the oil pan is overfilled, it could be excessive oil pressure.
Measure OP with mechanical gauge.[/quote:22004eadf8]
It could be excessive oil pressure. how can i solve it
thanx
Oil Stick
Engine oil out of the hole measuring(Oil Stick) engine oil & no smoke
Oct 16, 2010 at 1:46 AM
MMPRINCE4000
  • 8,548 POSTS
Measure with mechanical gauge to see what pressure is, at idle and at 2000rpm.
COuld be a bad oil pump or clogged oil galley.
Remove valve cover and look for sludge build-up.
Oct 17, 2010 at 1:44 AM
