1994 Ford Taurus driving the tie rod broke
1994 FORD TAURUS
25,000 MILES • 6 CYL • 2WD • AUTOMATIC
DYE
this bent up the right side steering stuff..
what is the cost to correct the front end?
Nov 4, 2008 at 10:11 AM
  • 31,937 POSTS
Hi there, a mechanic will have to inspect this damage and make an estimate, bent steering stuff is a bit hard to work with, it will have to be inspected first.
Mark (mhpautos)
Nov 4, 2008 at 10:17 AM
THIS IS MIKE
  • 686 POSTS
To replace only the tie rod and have the front end aligned may cost around $150 You should inspect all the other steering components as well.
Nov 5, 2008 at 8:31 AM
