1994 Ford Taurus change & replace front brake rotor
77,000 MILES • 6 CYL • FWD • AUTOMATIC
PROCAR
How to remove & replace front brake rotors on 1994 Ford Taurus GL
Nov 26, 2009 at 12:09 PM
BMRFIXIT
  • 19,053 POSTS
FRONT BRAKE ROTOR
Jack and support the vehicle
Remove tire
Remove front brake caliper and pads.
If caliper does not require service, DO NOT remove brake hose from caliper.
Secure caliper aside.
Remove rotor from hub assembly.
If rotor is difficult to remove, spray rust penetrant on front and rear of rotor/hub mating surfaces.
Using a hammer, strike rotor between studs.
If rotor is still difficult to remove, use a 3-jawed puller. To install rotor, reverse removal procedure
Apr 1, 2021 at 12:30 PM
