1994 Ford Taurus Brakes or booster vacuum supply
97,000 MILES • 6 CYL • FWD • AUTOMATIC
BADCO66
My brakes went out, put a master cyl on it and the petal still goes to the floor. The car will stop, all calipers are working. But the petal will not pump up. I can hear a swooshing sound inside the car by the brake petal when it is pressed could the booster vacuum supply be leaking. If so How do i check it ?
May 30, 2010 at 4:46 AM
  • 75,988 POSTS
The brake power booster is leaking -replace it
May 30, 2010 at 8:29 AM
BADCO66
Thank you
May 30, 2010 at 11:18 AM
