1994 Ford Taurus Body control module
129,000 MILES • 6 CYL • 2WD • AUTOMATIC
GETBACKMAN
Body control module was cracked and humming when attempting to start car. Replaced with new Body control module. Still doing same thing. Motor turns over good but will not start. Any suggestion/ Thanks
Feb 4, 2010 at 9:12 AM
BMRFIXIT
  • 19,053 POSTS
Did you check for spark
at the coil and at the wires by the spark plugs
also check for fuel pressure
check fuses
turn key on do you have check engine light on
check the ground wire and make sure that the constant control relay module has a good ground
CCRM is located on upper radiator support battery side
let me know what missing
Feb 4, 2010 at 11:14 AM
