How do I loosen the belt to put back on the car
RJBAKER
How do i loosen the belt to put back on the car. I replaced the alternator and now the belt will not go back on. it is a 3.2
Dec 19, 2008 at 4:23 AM
DAVE H
  • 13,383 POSTS
you will need to loosen the tensioner ? BELT ADJUSTMENT Tensioners may be used to automatically adjust belt tension to specification. Check belt for fraying. If fraying exists, ensure belt and tensioner are properly aligned. See Fig. 1 . Tensioners may contain a belt-wear indicator. See Fig. 2 . If tensioner reaches travel limit, as indicated by marks on tensioner, replace belt. Ensure serpentine belts are properly installed. See Fig. 3 -Fig. 5 . On vehicles without tensioners, ensure belt tension is within specification.
https://images.2carpros.com/forum/automotive_pictures/266999_ten_1.jpg
Jun 29, 2021 at 3:24 AM
SCHRIMPIEMAN
  • 166 POSTS
Make sure the alternator pulley is the same size as the one which was originally installed. I've had cases where the pulley was larger, which of course meant the belt would not ride up onto the pulley no matter how much I pulled on the tensioner.
The difference is so subtle sometimes, you don't even notice until you're pulling and swearing at the tensioner that it just won't fit.
