1994 Ford Taurus battery good car won't crank
WMEXRADIO
Engine Mechanical problem
1994 Ford Taurus 6 cyl Front Wheel Drive Automatic
possible dead spot on starter panel lights dim when ignition turned on
however could this be a starter relay malfunction
Jun 22, 2010 at 3:54 AM
  • 75,988 POSTS
No crank at all/nothing/nada:
Could be one of the following the starter, starter relay, clutch switch/park and neutral switch and ignition switch assuming the battery and connections are good. If it doesn't apply ignore it
Jun 22, 2010 at 9:46 PM
