Hi guys- i have a 1994 ford taurus sho and i need to remove the clutch pulley from the a/c compressor. I have taken the hub off,removed the broken part off the pulley, removed the snap ring and now cannot get the bearing off or the other broken piece that remains in tact as well as the rear field coil. The compressor is a new reman that was replaced in 5-07, so i must be doing something wrong. My sons and i are at wits end and have bailed out for the day. There is another snap ring further down under what appears to be a race, but that looks like it needs to be removed at a later time as i cannot. This is still on the vehicle and want to stay that way. Fyi its a nippondenso unit. Thanks! Aaron
Feb 3, 2008 at 6:03 AM
