1994 Ford Taurus 1994 Ford Taurus 3.0 Stalls out when it ge
85,000 MILES • 6 CYL • 2WD • AUTOMATIC
VEGASSOLO
1994 Ford Taurus 3.0, has been running strong until last week, after the car warms up, maybe 10 mins, 1-1/2 Miles the car stales out or sputter dies out if I'm trying to accelerate. If the car sits for 5-10mins, starts right up runs strong for about another 5-10mins and so on. I had it tuned up, new plugs, Rotor, cap and wires, new ignition coil, Ignition module, same problem. I’m thinking CCRM? Any way to check the Fuel Pump Relay in the CCRM? Note: Not 100% confirmed but I stuck a frozen gel pack under the CCRM and I believe I was able to drive and run the car longer before the car died again.
May 16, 2010 at 3:18 PM
BMRFIXIT
  • 19,053 POSTS
check for fuel pressure and power at the pump
if have power or low pressure suspect bad fuel pump
if no power suspect and replace the relay
May 16, 2010 at 11:01 PM
