[quote:6eec380a7b="thcastaway"]Transmission problem
1993 Ford Taurus 6 cyl Two Wheel Drive Automatic 98,000 miles
was driving on the freeway and the car downshifted and wont go back into 3rd gear/overdrive. am i screwed?[/quote:6eec380a7b]
How are 1st and 2nd? Is the transmission staying in 1st? Or does it shift to 2nd OK? If it does shift to 2nd, you probably have an internal failure that will require removal of the transmission to repair. If it stays in 1st, it is more likely a speed sensor.
Sep 1, 2009 at 11:21 AM
