1993 Ford Taurus Want run
140,000 MILES • 6 CYL • 2WD • AUTOMATIC
CARMANRM
I have a 1993 Ford Taurus with V-6. Its been sitting for over a year. After charging it and adding fuel injection cleaner to the gas, it cranked right up. After driving it for about 15 min, it started spark knocking to the point where sounds like a valve and cuts off. once it cools off it runs fine. As it gets hotter, the knocking gets worse until it finally cuts off again. What could cause this?
Oct 11, 2010 at 11:17 AM
  • 75,988 POSTS
Coule be overheating causing the spark knock-check the thermostat
Oct 11, 2010 at 11:23 AM
